Einleitung
Cameras can be damaged by water or by physical impact, but it is much easier to replace than you may think. Follow these few simple steps so that you can get back to capturing the world around you on your tablet.
Was du brauchst
Using a nylon spudger or a flat plastic opening tool, pry open the back of the device.
Using a phillips head screwdriver, remove the 6 4mm screws holding the battery on the device.
Remove the battery, and set it aside.
Using a phillips head screwdriver, remove the 6 4mm screws holding the motherboard in the device.
Locate the 8 flex cables attached to the motherboard.
Using a nylon spudger, gently detach each flex cable from the motherboard.
Lift the motherboard from the device and set it aside.
Locate the camera towards the top of the device.
Use a nylon spudger to gently lift the camera and remove it from the device.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
