Was du brauchst
Insert an opening pick between the rear case and the plastic rim.
Slide the pick along the edge of the rear case until you release the plastic clips attaching the rear case to the display.
Continue to slide the pick around the edge of the rear case until all clips are released.
Use the flat end of a nlyon spudger to pry up the black plastic tabs securing the two ZIF connectors.
Use the flat end of a nylon spudger to pry up the brown plastic tab securing the orange ribbon cable.
Remove all three ribbon cables by gently pulling the cables away from the ZIF connectors.
Use a Phillips #000 screwdriver to remove the ten 3mm screws securing the battery to the chassis.
Use the pointed end of a nylon spudger to pry the two battery connections away from the motherboard.
Use the flat end of a plastic spudger to pry up the press-fit connector from the motherboard.
Remove the camera by gently pulling upward with a pair of tweezers.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
I have noticed a couple of things on this article, so I figured i'd put them here.
The disconnection of the ZIF Ribbon cables doesn't seem necessary for the repair at all, & the complete removal of the battery from the chassis is unnecessary as well.
The camera is a small, singular part that doesn't connect to anything else.
For safety's sake, I'd personally still recommend you disconnect the battery, to ensure there's no power flowing through the system, but complete removal is highly unnecessary.
