Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
  1. Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart. Be careful when removing the screen as negligence can cause damage.
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands. Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port. Note: the connection lifts up to remove.
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. After the battery is disconnected, use the pulling tab to safely remove the battery.
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Take the plastic remover tool and gently lift the component free from the motherboard. Take the plastic remover tool and gently lift the component free from the motherboard. Take the plastic remover tool and gently lift the component free from the motherboard.
    • Take the plastic remover tool and gently lift the component free from the motherboard.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
anthony gonzalez
301 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 4-2, Brown Fall 2014 Mitglied von USF Tampa, Team 4-2, Brown Fall 2014
USFT-BROWN-F14S4G2
3 Mitglieder
26 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 3
Insgesamt: 530
