Einleitung
This guide will take you through the step-by-step process of removing and replacing the motherboard of a Samsung Galaxy Tab 3 8.0.
Was du brauchst
Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
After the battery is disconnected, use the pulling tab to safely remove the battery.
Unscrew the 2.9mm screws from the speakers using a Phillips head #000 screwdriver, then lift the speakers from the device.
Using the plastic remover tool carefully unseat the four rectangular electric leads from the board. Each rectangle is a different size, the first one is large, the second one is medium, and the last two are small.
Using the plastic remover tool carefully unseat the square electric lead (marked in orange) from the board.
Using the plastic remover tool carefully unseat the small square and the two rectangular electric leads (marked in yellow) from the board.
Unscrew the one 2.9mm Phillips #000 screw above the battery, and the three 2.9mm Phillips #000 screws to the right of the battery.
12 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
You don’t need to remove the battery in order to remove the motherboard. Just disconnect the battery!
