Einleitung
If you are experiencing issues with no audio or unclear audio while using the Samsung Galaxy Kids Tab 3 7.0, use this guide to replace the aux port. The aux port allows audio transmission through an auxiliary cord, and may be causing the issue.
Before starting with the replacement guide, remove any dust or debris from the port and try several different auxiliary cords to ensure the root cause of the audio issue is the aux port.
Was du brauchst
Wedge the plastic opening tool in the seam between the screen and the back cover.
Slide the tool around all the edges and remove the screen from the back cover.
Lift up the (ZIF) zero insertion force connectors using the plastic opening tool, separating the connectors from the ribbon cables.
Remove the ten 4 mm Phillips #000 screws holding the motherboard to the device.
2 weitere Personen haben diese Anleitung absolviert.
