Zum Hauptinhalt wechseln
Samsung Galaxy Tab 3 Kids Speaker Replacement
Was du brauchst
  1. Samsung Galaxy Tab 3 Kids Speaker Replacement, Speaker: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab 3 Kids Speaker Replacement, Speaker: Schritt 1, Bild 2 von 2
    • Using the plastic opening tool to open up the device, wedge in the seam between the screen and the back cover. Slide the tool around all the edges and remove the screen from the back cover
  2. Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 2, Bild 1 von 1
    • Unplug the battery connection carefully using the plastic opening tool.
  3. Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 3, Bild 3 von 3
    • Before Changing the motherboard, you have to lift up the (ZIF) zero insertion force by using the plastic opening tool, separating the connector from the batter ribbon cable
  4. Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the ten 4mm PH000 bolts holding the motherboard on the device
  5. Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 5, Bild 3 von 3
    • Remove the mother board from the device by carefully lifting it out.
  6. Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove the last screw holding down the speaker.
  7. Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 7, Bild 1 von 3 Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 7, Bild 2 von 3 Samsung Galaxy Tab 3 Kids Speaker Replacement: Schritt 7, Bild 3 von 3
    • Remove the speaker using the plastic splunger
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
ajhoffman
182 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 2-6, Nance Fall 2016 Mitglied von USF Tampa, Team 2-6, Nance Fall 2016
USFT-NANCE-F16S2G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 181
