Einleitung
Replacement guide for the digitizer on a Samsung Galaxy Tab 4 10.1 android tablet.
Was du brauchst
Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
Peel off the green tape that covers the connectors for the three black strips.
Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
Wedge an opening pick between the digitizer and display frame.
Slide the opening pick around the perimeter to separate the two pieces.
7 weitere Personen haben diese Anleitung absolviert.
