Einleitung
Replacement guide for the IR sensor in a Samsung Galaxy Tab 4 10.1 android tablet.
The battery only needs to be disconnected—skip steps 2, 3, 5, and 6.
Was du brauchst
Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
Peel off the green tape that covers the connectors for the three black strips.
Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
Use the flat end of a spudger to disconnect the IR sensor press-fit connector from the motherboard.
