Zum Hauptinhalt wechseln
Samsung Galaxy Tab 4 10.1 IR Sensor Replacement
Was du brauchst
  1. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab 4 10.1 IR Sensor Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: Schritt 2, Bild 1 von 1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: Schritt 5, Bild 1 von 1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: Schritt 6, Bild 1 von 1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement, IR Sensor: Schritt 7, Bild 1 von 2 Samsung Galaxy Tab 4 10.1 IR Sensor Replacement, IR Sensor: Schritt 7, Bild 2 von 2
    • Use the flat end of a spudger to disconnect the IR sensor press-fit connector from the motherboard.
  8. Samsung Galaxy Tab 4 10.1 IR Sensor Replacement: Schritt 8, Bild 1 von 1
    • Remove the IR sensor.
Abschluss
Blake Klein
70.919 Reputation
50 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 638
