Zum Hauptinhalt wechseln
Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement
Was du brauchst
  1. Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert the wedge of the nylon spudger and slide it between the front and back panels until the back comes off.
  2. Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement: Schritt 2, Bild 1 von 1
    • Peel off the green tape that covers the connectors for the three black strips.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps.
  3. Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the four 3.2mm screws.
  4. Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement: Schritt 4, Bild 1 von 1
    • Detach the red, blue, and black cables by prying up on the white connector from the motherboard.
    • If using fingers instead, pull evenly on the full width of the cable so the wires are not overly strained.
    • If you pull too hard you can damage the connector on the circuit board. Use a spudger or tweezers to push down on the black connector on the board while gently prying the battery connector loose. The connector breaks VERY easily.
  5. Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement: Schritt 5, Bild 1 von 1
    • Use the nylon spudger to remove the battery by prying up on the edges.
  6. Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement: Schritt 6, Bild 1 von 1
    • Once the battery is loose, lift it out of the device.
  7. Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement, Motherboard: Schritt 7, Bild 1 von 2 Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Remove the two 2.7mm Phillips #00 screws from the motherboard.
  8. Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement: Schritt 8, Bild 2 von 2
    • Use the flat end of a spudger to pry up and disconnect the five press-fit connectors from the motherboard.
  9. Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement: Schritt 9, Bild 1 von 2 Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement: Schritt 9, Bild 2 von 2
    • Use a spudger to pry up the motherboard, and remove it from the device.
  10. Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement, Loudspeaker: Schritt 10, Bild 1 von 2 Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement, Loudspeaker: Schritt 10, Bild 2 von 2
    • Insert the pointed end of a spudger underneath the ribbon connector of the left loudspeaker.
    • Pry upwards to remove the loudspeaker.
  11. Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement: Schritt 11, Bild 1 von 2 Samsung Galaxy Tab 4 10.1 Loudspeaker Replacement: Schritt 11, Bild 2 von 2
    • Insert the pointed end of a spudger underneath the headphone jack .
Abschluss
Blake Klein
70.534 Reputation
50 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 425
