Einleitung
If you don't have the heating pad available, either use a heat gun or a hair dryer with a high heat setting.
Was du brauchst
Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
Using the plastic opening tool, gently pry the chip connections away from the motherboard.
Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
Work the spudger underneath the battery as shown and pry the battery away from the phone case.
Evenly heat the surface of the screen using your heating tool to loosen the adhesive that is holding the screen to the phone case.
Carefully insert the spudger between the glass and the chrome outer frame of the tablet.
Now, slowly pry your way around the screen to loosen the glass from the frame.
After you’ve removed the glass from the screen, feed the chip connection through the phone casing.
36 weitere Personen haben diese Anleitung absolviert.
11 Kommentare
Do you have to remove the battery to replace the screen?
This worked perfectly for me. I just bought the assembly instead of going through the full deal (which if I had it would have saved me about 30 bucks overall). But was easy enough to do anyway. I still intend to get the digitizer/glass and finish so I have a spare for future breaks. (I have kids and they are hard on these tablets)
