Einleitung
Battery life is crucial to maximizing your tablet's utility. This guide will show you the step by step replacement of the Samsung Galaxy Tab 4 8.0 battery. Although replacement is fairly easy, if your tablet's battery has more adhesive than usual, extra force will be needed.
Was du brauchst
At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
Firmly grasp the back plastic casing and lift it away from the front assembly panel.
Peel up the detachable corner of the white plastic sticker that reads “pull (hands only).”
Using your thumb and index finger, pinch the tab and pull it up to remove the top right corner of the battery from the front panel assembly.
Run the spudger under the battery to disconnect the red and blue cable connector from the circuit.
Lift the battery towards you, away from the front panel.
17 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Worked great! Would have been better if I had the pry tools though. I am getting them next week :}
In order to open, I did not want to purchase a pry tool so I used a think screwdriver to open abit and inserted an old credit card that made the job without danger.
