Zum Hauptinhalt wechseln
Samsung Galaxy Tab 4 8.0 Verizon Display Replacement
Was du brauchst
  1. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Motherboard: Schritt 1, Bild 1 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Motherboard: Schritt 1, Bild 2 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  2. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 2, Bild 3 von 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  3. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 3, Bild 3 von 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  4. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 4, Bild 3 von 3
    • Using the spudger gently wedge the blue wire out of its compartment.
  5. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 5, Bild 1 von 1
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  6. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  7. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 7, Bild 1 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 7, Bild 2 von 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 7, Bild 3 von 3
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  8. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 8, Bild 2 von 2
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  9. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 9, Bild 1 von 1
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  10. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 10, Bild 1 von 2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 10, Bild 2 von 2
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
  11. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Display: Schritt 11, Bild 1 von 1
    • Insert an opening pick in between the display screen and the display frame.
  12. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 12, Bild 1 von 1
    • Wedge four of the opening picks in between the display screen and the device backing on all four corners.
  13. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 13, Bild 1 von 2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 13, Bild 2 von 2
    • Wedge the Jimmy between the display and the device backing at a corner.
    • Cut through the adhesive that is securing the screen to the device on all four sides.
  14. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 14, Bild 1 von 2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: Schritt 14, Bild 2 von 2
    • Once the display is completely disconnected from the device gently remove it without touching the screen which lies underneath.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Umm….how do you remove the rear cover?
Gregg Stanley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 499
