Einleitung
Volume and lock buttons are crucial to facilitate the use and safety of any device. Replacing these components are a breeze. For this guide, all you need are these easy steps and a few tools to facilitate the process.
Was du brauchst
At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
Firmly grasp the back plastic casing and lift it away from the front assembly panel.
The button will be attached to the back casing of the tablet.
Using the spudger, first push the power/lock button then the volume button inwards from the opening towards the center of the tablet.
Using a precision tweezer, detach the clear plastic wire from the back casing by pulling the wire out of its slot.
Grab the power/volume button with a precision tweezer to completely lift the buttons out of the back casing.
2 weitere Personen haben diese Anleitung absolviert.
