Zum Hauptinhalt wechseln
Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement
Was du brauchst
  1. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: Schritt 1, Bild 1 von 3 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: Schritt 1, Bild 2 von 3 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Before disassembling your Samsung Galaxy Tab 4 8.0, be sure it is powered off and you remove the SIM and Micro SD cards.
    • At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
    • Do not use excessive force when prying the clips, fastening the casing together, open because they can easily break.
  2. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: Schritt 2, Bild 2 von 2
    • Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
    • As right-handers, we found it easiest to move clockwise and use more pressure around the corners to facilitate the process.
    • You might hear several popping noises caused by the plastic clips coming undone.
  3. Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Tab 4 8.0 Verizon Rear Case Replacement: Schritt 3, Bild 2 von 2
    • To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
    • Firmly grasp the back plastic casing and lift it away from the front assembly panel.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Ofelia Cruz
1.119 Reputation
5 Anleitungen geschrieben
CSU Fullerton, Team 1-3, Bruce Fall 2015 Mitglied von CSU Fullerton, Team 1-3, Bruce Fall 2015
CSUF-BRUCE-F15S1G3
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 908
