Einleitung
Use this guide to replace the rear case on your Samsung Galaxy Tab 4 8.0.
Was du brauchst
At the top of the tablet, nudge the blue plastic opening tool between the back plastic casing and the front panel's metal rim.
Continue prying the blue plastic opening tool along the perimeter of the tablet to separate the back plastic casing from the front assembly panel.
To avoid damaging the screen, gently set the tablet with the LCD screen faced down.
Firmly grasp the back plastic casing and lift it away from the front assembly panel.
Eine weitere Person hat diese Anleitung absolviert.
