Einleitung
This guide will show you how to safely remove the battery from the Samsung Galaxy Tab 4 8.0 Wi-Fi model. Enjoy the new battery for your tablet! It will definitely outlast the replaced battery.
Was du brauchst
Gently insert the plastic opening tool between the metal rim and the back plastic casing at the bottom of the tablet and pry the back casing away from the device. Continue to separate the back panel of the device from the front assembly.
Place the tablet screen down on a clean surface.
Grasp the back panel and lift it from the device.
Peel the sticker, reading "PULL (HANDS ONLY)," off of the battery starting at the detachable corner.
Use the spudger to disconnect the battery connector by running it along the underside of the battery.
Lift the battery out of the assembly.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
