Zum Hauptinhalt wechseln
Samsung Galaxy Tab 4 Motherboard Replacement
Was du brauchst
  1. Samsung Galaxy Tab 4 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab 4 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
    • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
  2. Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Carefully remove the back panel from the frame of the device.
  3. Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
  4. Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
    • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
  5. Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
    • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
  6. Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  7. Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 7, Bild 1 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 7, Bild 2 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  8. Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 8, Bild 1 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 8, Bild 2 von 3 Samsung Galaxy Tab 4 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
    • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 18-3, Forte Fall 2016 Mitglied von Cal Poly, Team 18-3, Forte Fall 2016
CPSU-FORTE-F16S18G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 1,741
