Zum Hauptinhalt wechseln
Samsung Galaxy Tab 7.7 Battery Replacement
Was du brauchst
  1. Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: Schritt 1, Bild 1 von 3 Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: Schritt 1, Bild 2 von 3 Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: Schritt 1, Bild 3 von 3
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Battery Replacement, Disconnecting the battery: Schritt 2, Bild 1 von 1
    • Detach the five wire connection of the battery from the motherboard. You will need to gently insert a flat head screwdriver under the connector, and using left to right motion with your wrist, create a small space separating the connector from its connection. Gradually make the space wider until the connector pops out of its socket.
  3. Samsung Galaxy Tab 7.7 Battery Replacement, Unscrewing the battery: Schritt 3, Bild 1 von 1
    • Remove the 6 screws securing battery.
  4. Samsung Galaxy Tab 7.7 Battery Replacement, Replacing the battery: Schritt 4, Bild 1 von 1
    • Remove the original battery, replace it with a new one.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 13-2, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 22
Insgesamt: 7,767
