Was du brauchst
Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
Slide the second plastic opening tool along the edge of the device to separate the back cover.
Locate the motherboard and 5 connectors on it.
Pry up and detach the connector from the motherboard using the flat edge of the spudger.
Repeat for the 4 remaining connectors.
Using the Phillips #00 screwdriver, unscrew the 3 screws (1mm) that are located near:
Camera
Power and volume buttons
Tilt sensor
After removing motherboard from device, flip motherboard over.
Using flat side of Spudger, lift orange tab connecting the flex ribbon of the camera to the motherboard.
