Videoanleitungen
Fast fertig!
Abschluss
11 weitere Nutzer haben diese Anleitung absolviert.
5 Kommentare
si on a pas conserver le pcb qu’il enlève de l’écran cassé on peux le racheter ou?
Yacine Chennoufi - Antwort
How do you heat up the screen to loosen the glue? Heat gun? Blow dryer? How do you keep from damaging it from getting too hot? Thanks :)
Justin Shields - Antwort
Use a heat gun it will help that’s what I would do
nicholaswiding -
Best and safest way to heat up a device to remove screen is with a heating mat………. i set mine at 75deg
Alan Sears - Antwort
Can you replace just the glass and not the glass-digitiser unit?
Gary Shearin - Antwort
