Zum Hauptinhalt wechseln
Samsung Galaxy Tab A 7.0" Headphone Jack Replacement
Was du brauchst
  1. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 1 von 1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: Schritt 3, Bild 3 von 3
    • Remove the two Phillips head screws attaching the auxiliary port to the plastic frame using a P000 screwdriver.
    • Remove the four Phillips head screws attaching the motherboard to the plastic case using a P000 screwdriver.
  4. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: Schritt 4, Bild 1 von 1
    • Using tweezers disconnect the headphone jack connector from the motherboard.
  5. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: Schritt 5, Bild 3 von 3
    • Using tweezers, carefully lift up the motherboard.
    • Using tweezers, remove the metal jacket holding the headphone jack in place by grabbing the left corner where there is a recess to grab it.
    • There is a light adhesive holding the metal jacket down. You may have to pull slightly harder to get this off.
  6. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: Schritt 6, Bild 1 von 1
    • Remove the auxiliary port from the case.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Bradley Watson
1.028 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 5-4, Passmore Spring 2017 Mitglied von USF Tampa, Team 5-4, Passmore Spring 2017
USFT-PASSMORE-S17S5G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 3
Letzten 7 Tage: 13
Letzten 30 Tage: 70
Insgesamt: 3,242
