Einleitung
If your display is unresponsive or cracked, this is the guide for you! As you follow the steps below, please be careful to not damage the other components.
  1. Insert a metal spudger between the back case and the screen of the device.
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
      • There will be an audible click every time a snap releases.
    Kommentar hinzufügen
  2. Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
    • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
    • Place one hand on the battery and grasp the outer edge of the device with the other hand.
    • Flip the device over so that the battery falls over and onto your hand.
    • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
    • Hold the battery and grip the wires with your thumb and finger.
    • Pull the wires away from the device to remove the white connector from the black socket.
    • Lift the battery away from the device.
  3. Kostenloser Versand bei Bestellungen über 20 $
    Verwende den Code BLUEANDBLACK an der Kasse
    • Remove the green tape that is covering the ZIF connections.
    • Use a plastic opening tool to lift the black tab on both ZIF connectors.
    • Use a spudger to release the display flex able from the ZIF connector.
    • Pull out the front facing camera.
    • Undo the press connectors with a plastic opening tool.
    • Remove the two 2.8mm screws holding in the magnetic brackets with a PH00 bit.
    • Pull out the two magnetic brackets.
    • Remove the four 2.8mm screws holding in the daughterboard with a PH00 bit.
    • Use a spudger to help lift up the daughterboard.
      • There is some glue so pry carefully.
    • Remove the daughterboard.
    • Remove the four 2.8mm screws holding in the motherboard with a PH00 bit.
    • Pull out the motherboard.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Blake Klein
Mitglied seit 29.01.2017
36.951 Reputation
35 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
114 Mitglieder
7.039 Anleitungen geschrieben
Hi Blake, this stops before getting to the screen?
Tom Kell - Antwort
lollllllll.. this is incomplete
mrdamnslow - Antwort
Can someone tell me what the press connectors do? They are hot to the touch when I have it plugged in. I'm trying to fix a tablet that doesnt turn on and is hot.
Erik Paul Vasquez - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 12
Letzte 7 Tage: 63
Letzte 30 Tage: 242
Insgesamt: 2,431
