Zum Hauptinhalt wechseln
Samsung Galaxy Tab A 9.7 Speakers Replacement
Was du brauchst
  1. Samsung Galaxy Tab A 9.7 Speakers Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab A 9.7 Speakers Replacement, Speakers: Schritt 2, Bild 2 von 2
    • Remove the two 2.8 mm Phillips #000 screws from the speakers.
  3. Samsung Galaxy Tab A 9.7 Speakers Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Heavy-Duty Spudger
    Kaufen
    • Each speaker is now only connected to the main device by small plastic snaps.
    • Pry the speakers from the device at these two points using the heavy duty spudger.
Abschluss
Cal Poly, Team S1-G3, Livingston Spring 2017 Mitglied von Cal Poly, Team S1-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S1G3
1 Mitglied
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 27
Insgesamt: 1,518
