Zum Hauptinhalt wechseln
Samsung Galaxy Tab A Earphone Jack Replacement
Was du brauchst
    1. Samsung Galaxy Tab A Earphone Jack Replacement, Earphone Jack: Schritt 1, Bild 1 von 1
      • Make sure the device is turned off before attempting to disassemble it.
      • At the top portion of the memory card slot, use the small metal spudger to create separation between the back cover and the rest of the device.
      • The small metal spudger is only used to create separation between the back cover and the rest of the device, not to remove the back cover.
      Frag FixBot
      Kommentar hinzufügen
    2. Samsung Galaxy Tab A Earphone Jack Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab A Earphone Jack Replacement: Schritt 2, Bild 2 von 2
      • Use the intermediate metal spudger in place of the small metal spudger to remove the back cover. This is done by sliding the intermediate metal spudger around the perimeter of the device, beginning at the top portion of the memory card slot.
      • The second picture shows the internal portion of the device once the back cover is removed.
      Frag FixBot
    3. Samsung Galaxy Tab A Earphone Jack Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Tab A Earphone Jack Replacement: Schritt 3, Bild 2 von 2
      • Use the spudger to disconnect the earphone jack from the motherboard.
      • To prevent any damage to either the earphone jack or motherboard, it is recommend to remove the jack at its blue rubber portion.
      • The connected and disconnected earphone jack is shown in the first and second picture, respectively.
      Frag FixBot
    4. Samsung Galaxy Tab A Earphone Jack Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab A Earphone Jack Replacement: Schritt 4, Bild 2 von 2
      • Use the PH0 screwdriver bit to remove the 2.5 mm screws attaching earphone jack to the rest of the device.
      • The second picture shows this process in action.
      Frag FixBot
    5. Samsung Galaxy Tab A Earphone Jack Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Tab A Earphone Jack Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Tab A Earphone Jack Replacement: Schritt 5, Bild 3 von 3
      • Use the spudger to fully remove the earphone jack from the rest of the device.
      • The second picture shows what the device should look like once the earphone jack has been removed.
      Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 17-4, Blackwell Winter 2016 Mitglied von USF Tampa, Team 17-4, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G4
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 58
Insgesamt: 5,931
