Zum Hauptinhalt wechseln
Einleitung
The back panel of the Samsung Galaxy Tab E 8.0 can be damaged if the back panel is struck by a hard object. This guide shows how to replace the back panel of the tablet by separating it from the screen.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen. Make sure the device is off and the SD card is removed before taking off the back casing.
    • Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
    • Make sure the device is off and the SD card is removed before taking off the back casing.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
Abschluss
Scott Kampfen
156 Reputation
1 Anleitung geschrieben
Cal Poly, Team S13-G4, White Fall 2018 Mitglied von Cal Poly, Team S13-G4, White Fall 2018
CPSU-WHITE-F18S13G4
4 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 25
Insgesamt: 191
