Zum Hauptinhalt wechseln
Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement
Was du brauchst
  1. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement, Back Camera: Schritt 1, Bild 1 von 1
    • Make sure the device is turned off.
    • Using the plastic opening tool, start in the center and wedge the angled tip between the plastic back and the scree.
    • Try to pressure it, wedge it back and forth.
    • Do not wedge the plastic opening tool directly on top of the power buttons and headphone buttons.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: Schritt 2, Bild 2 von 2
    • Once the bottom edge has been loosened, use the suction tool to pull it.
    • The second picture shows the internal portion of the tablet once the back cover is removed.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: Schritt 3, Bild 2 von 2
    • The first picture shows the location of back camera.
    • Disconnect the rectangular connection from the back camera to the motherboard.
  4. Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab E 9.6 Verizon Back Camera Replacement: Schritt 4, Bild 2 von 2
    • The picture illustrates what the device should look like once the back camera is removed.
Abschluss
USF Tampa, Team 1-4, Cagle Fall 2016 Mitglied von USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 1,259
