Zum Hauptinhalt wechseln
Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement
Was du brauchst
  1. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Back Casing: Schritt 1, Bild 1 von 1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: Schritt 2, Bild 3 von 3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: Schritt 3, Bild 3 von 3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
  4. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Speaker: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement, Speaker: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Locate the speaker in the top right corner of the back casing. Use a pair of tweezers to pull peel up the film connecting the speaker to the case.
  5. Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Tab E 9.6 Verizon Speaker Replacement: Schritt 5, Bild 2 von 2
    • Once you've detached the film connecting the speaker to the case, use the tweezers to remove the speaker completely.
Abschluss
USF Tampa, Team 1-4, Cagle Fall 2016 Mitglied von USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 Mitglieder
14 Anleitungen geschrieben
2 Kommentare
Then what? How does this fix the problem? Can I tweek the speaker? Do I buy a new, more powerful speaker? What is your point in this post?
Janet - Antwort
@Janet Sorry I know you probably wont even see this, but its to help those who wish to replace a broken speaker, its not about implanting a 9” subwoofer. Sorry but sometimes the simplest of explanations will often answer your questions.
sannas30 -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 1,363
