Zum Hauptinhalt wechseln
Samsung Galaxy Tab E Lite 7 Kids Battery Replacement
Was du brauchst
  1. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: Schritt 1, Bild 1 von 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: Schritt 1, Bild 2 von 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: Schritt 2, Bild 2 von 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use the plastic opening tool to gently lift the black ZIF (zero insertion force) connector shown within the red circle.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to gently lift black ZIF (zero insertion force) connector shown within the red square.
    • Now gently pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Tab E Lite 7 Kids Battery Replacement: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool and gently pry out the battery from the left-hand side.
    • Grab the battery and lift it up.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S19-G2, Hoffman Spring 2017 Mitglied von USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Great information.  You need to show how to replace a screen- LCD for a Samsung Galaxy TAB E Lite Kids.
Paul McWilliams - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 3,003
