Einleitung
This replacement guide will show you how to replace the motherboard in your Samsung Galaxy Tab E Lite 7 Kids. You will need to follow the instructions carefully as to not damage any fragile components in your tablet.
Was du brauchst
Using a plastic opening tool, wedge in the seam between the screen and the case.
Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
After separating the latches holding the screen and case together, slowly take the screen off the case.
Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
Use your hands to pull the black cable out of its slot.
Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
Pull out the battery's ribbon cable.
Use the plastic opening tool to lift up the latch to the ribbon cable.
Remove the ribbon cable from the connector.
Use the plastic opening tool to pry up the tab holding the motherboard in place.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
