Zum Hauptinhalt wechseln
Samsung Galaxy Tab E Lite 7 Kids Speaker Replacement
Was du brauchst
  1. Samsung Galaxy Tab E Lite 7 Kids Speaker Replacement, Rear Case: Schritt 1, Bild 1 von 3 Samsung Galaxy Tab E Lite 7 Kids Speaker Replacement, Rear Case: Schritt 1, Bild 2 von 3 Samsung Galaxy Tab E Lite 7 Kids Speaker Replacement, Rear Case: Schritt 1, Bild 3 von 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Speaker Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab E Lite 7 Kids Speaker Replacement: Schritt 2, Bild 2 von 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Using a spudger, pry up the speaker ribbon cable.
  4. Samsung Galaxy Tab E Lite 7 Kids Speaker Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Tab E Lite 7 Kids Speaker Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Tab E Lite 7 Kids Speaker Replacement: Schritt 4, Bild 3 von 3
    • Using the plastic opening tool, place it on the opening in the plastic around the speaker.
    • Pry the speaker out of its seat.
Abschluss
USF Tampa, Team S19-G2, Hoffman Spring 2017 Mitglied von USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 350
