Zum Hauptinhalt wechseln
Samsung Galaxy Tab Pro 8.4 Back Camera Replacement
Was du brauchst
  1. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 2, Bild 2 von 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 4, Bild 1 von 1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 5, Bild 1 von 1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Motherboard: Schritt 6, Bild 1 von 3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Motherboard: Schritt 6, Bild 2 von 3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Remove all the clips that are attached to the motherboard using your fingers or a nylon spudger.
  7. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 7, Bild 1 von 3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 7, Bild 2 von 3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 7, Bild 3 von 3
    • There are four Phillips head screws (2.5mm) that need to be removed:
    • Two on the charging port, which is the small metallic piece at the bottom of the device.
    • There is one screw that is covered by a small green tape. The tape must be peeled off before the screw under can be removed.
    • The last screw is found on a speaker at the bottom right of the device. Once the screw is removed, the speaker must be removed as well.
  8. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 8, Bild 1 von 3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 8, Bild 2 von 3 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 8, Bild 3 von 3
    • There is a small wire that connects the motherboard to the bottom right corner.
    • Gently pull the end of the wire that attaches the motherboard to the device until the wire is disconnected.
    • After the cord is disconnected, the motherboard can be removed from the tablet by simply lifting it from the device.
  9. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Back Camera: Schritt 9, Bild 1 von 2 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement, Back Camera: Schritt 9, Bild 2 von 2
    • Once the motherboard has been removed, use a plastic opening tool to gently push the camera out of its place.
  10. Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 10, Bild 1 von 2 Samsung Galaxy Tab Pro 8.4 Back Camera Replacement: Schritt 10, Bild 2 von 2
    • Using your fingers, gently pull the camera out of its place.
Abschluss
Mario Montoya
225 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 9-2, Lacy Fall 2016 Mitglied von USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 662
