Einleitung
This guide will show you how to take off the back panel of the device and take out and replace the battery.
Was du brauchst
Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
Continue around the entire device until the back panel is completely separated from the screen.
Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
The battery should be completely disconnected and the new one can be installed.
21 weitere Personen haben diese Anleitung absolviert.
