Zum Hauptinhalt wechseln
Samsung Galaxy Tab Pro 8.4 Charging Port Replacement
Was du brauchst
  1. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Battery: Schritt 1, Bild 1 von 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
    • Insert the plastic opening tool between the edge of the glass screen and the metal frame around the device.
  2. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: Schritt 2, Bild 2 von 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: Schritt 3, Bild 2 von 2
    • Remove the four 2.5mm Phillips #000 screws.
  4. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Gently pull up on the plastic tab that has red, blue and black wires that connects the battery to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: Schritt 5, Bild 1 von 1
    • The battery should be completely disconnected and the new one can be installed.
  6. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: Schritt 6, Bild 1 von 2 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement, Charging Port: Schritt 6, Bild 2 von 2
    • Remove the two 2.5mm Phillips #000 screws.
  7. Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: Schritt 7, Bild 1 von 3 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: Schritt 7, Bild 2 von 3 Samsung Galaxy Tab Pro 8.4 Charging Port Replacement: Schritt 7, Bild 3 von 3
    • Gently pull up on tab that connects the charging port to the motherboard
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Jonathan Romine
1.072 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 9-2, Lacy Fall 2016 Mitglied von USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
4 Mitglieder
10 Anleitungen geschrieben
3 Kommentare
Thank you for your help. You are awesome :-)
Kim Williams - Antwort
I did all of this and battery says “not charging” while plugged in. Replaced both battery and port.
Brandon Torzeski - Antwort
Hey Thanks guys! I was interested in the data port / charging port flex cable replacement.
It could not be easier. Cheers folks.
Jim Kirkey
Jim Kirkey - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 4,023
