Zum Hauptinhalt wechseln
Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement
Was du brauchst
  1. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement, Stereo Speakers: Schritt 1, Bild 1 von 1
    • Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
  2. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 2, Bild 1 von 2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 2, Bild 2 von 2
    • Continue around the entire device until the back panel is completely separated from the screen.
  3. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 3, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the 2.5mm Phillips head screw on the top part of the speaker.
  4. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 4, Bild 2 von 2
    • Using your fingers, carefully remove the tab that connects the speaker to the motherboard.
  5. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 5, Bild 3 von 3
    • Using your fingers, gently remove the speaker from its place.
  6. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 6, Bild 1 von 3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 6, Bild 2 von 3 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 6, Bild 3 von 3
    • Use a Phillips #000 screwdriver to remove the 2.5mm Phillips head screw on top of the speaker.
  7. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 7, Bild 1 von 2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 7, Bild 2 von 2
    • Using your fingers, lift the tab that connects the speaker to the mother board.
  8. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 8, Bild 1 von 1
    • Using a nylon spudger, gently lift the round piece that connects to the speaker and remove it from its place.
  9. Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 9, Bild 1 von 2 Samsung Galaxy Tab Pro 8.4 Stereo Speakers Replacement: Schritt 9, Bild 2 von 2
Abschluss
Mario Montoya
225 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 9-2, Lacy Fall 2016 Mitglied von USF Tampa, Team 9-2, Lacy Fall 2016
USFT-LACY-F16S9G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 621
