Einleitung
If one or both speakers on your tablet are not working properly, this guide will walk you through how to easily replace them.
Was du brauchst
Begin by separating the back panel from the screen glass assembly using the plastic opening tool.
Continue around the entire device until the back panel is completely separated from the screen.
Use a Phillips #000 screwdriver to remove the 2.5mm Phillips head screw on the top part of the speaker.
Using your fingers, carefully remove the tab that connects the speaker to the motherboard.
Use a Phillips #000 screwdriver to remove the 2.5mm Phillips head screw on top of the speaker.
Using your fingers, lift the tab that connects the speaker to the mother board.
Using a nylon spudger, gently lift the round piece that connects to the speaker and remove it from its place.
