Zum Hauptinhalt wechseln
Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement
Was du brauchst
  1. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: Schritt 2, Bild 1 von 1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement, Headphone Jack/Speakers Assembly: Schritt 4, Bild 2 von 2
    • Remove the two 2 mm Phillips #000 securing the headphone jack.
  5. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the blue connector by gently popping it off of the motherboard with a plastic opening tool.
  6. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: Schritt 6, Bild 2 von 2
    • Use the metal spudger to pry from the top left corner of the headphone jack/lower speaker assembly.
    • Gently lift the headphone jack/lower speaker assembly free of the device.
  7. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: Schritt 7, Bild 1 von 1
    • Locate the top speaker.
    • Use a plastic opening tool to disconnect the green-gold upper speaker connector from the motherboard.
  8. Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy Tab S 8.4 Headphone Jack/Speakers Assembly Replacement: Schritt 8, Bild 2 von 2
    • Use a spudger to pry the uper speaker up and away from the device.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Trent Chapman
1.384 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 12-15, Maness Fall 2015 Mitglied von Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 21
Letzte 30 Tage: 27
Insgesamt: 3,393
