Zum Hauptinhalt wechseln
Samsung Galaxy Tab S 8.4 Micro USB Port Replacement
Was du brauchst
  1. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: Schritt 2, Bild 1 von 1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: Schritt 3, Bild 1 von 1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: Schritt 4, Bild 1 von 2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: Schritt 4, Bild 2 von 2
    • Remove the two 4 mm Phillips #000 screws securing the micro USB port.
  5. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool, disconnect the charge port from the motherboard.
    • Once disconnected, lift to remove the charging port.
Abschluss
32 weitere Personen haben diese Anleitung absolviert.
Trent Chapman
1.378 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 12-15, Maness Fall 2015 Mitglied von Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 Mitglieder
12 Anleitungen geschrieben
6 Kommentare
It is so amazing and it works!
alva chan - Antwort
Thanks a lot!
You make me a big economy by doing this myself with YOUR instructions !
Raphael
refelo123 - Antwort
What model number is this device specifically? It says WiFi, but I have the same one from a network carrier. Would this charging port work for that? Model sm-707v is the one that I have.
tailoredtoteach - Antwort
Thanks for the instructions, it looks simple , so I ordered the docking assembly and I replace it by myself.
You saved me a lot of money, thanks again!
wim-zelf - Antwort
With these instructions I ordered part from Amazon and replaced charging port and tablet charges again. Thanks!
Philip Holly - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 38
Insgesamt: 15,374
