Einleitung
If the tablet is not staying on unless plugged in, replacing the battery should solve the problem.
Was du brauchst
Apply heat using an iFixit iOpener or another heating gun in order to weaken the adhesive around the edges of the screen.
Insert the plastic opening tool into the gap between the screen and tablet in the location where you want to start removing the screen.
Put an opening pick in the gap created, in between the screen and the panel.
Repeat all around device, putting 2 picks on top and bottom, and one on each side.
Carefully remove the small suction cup from the corner without moving the screen.
Place the small suction cup in the center of the screen and lift to remove screen.
Place the plastic opening tool underneath the ribbon cable connecting the screen to the tablet.
Carefully lift the plastic opening tool to detach the ribbon from the tablet.
Remove the 13 3mm screws from around the edges of the board using a Phillips #1 screwdriver head.
Lift up and remove the panel of the board using a plastic opening tool.
Remove the cable that connects the battery and device using the plastic opening tools.
You can now safely remove the battery from the device by lifting it from the paper flap.
15 weitere Nutzer:innen haben diese Anleitung absolviert.
15 Kommentare
Humm u’ve just had to remove the back cover the battery is here no need to remove the screen
OMG thank you I definitely would have followed the instructions you’re absolutely right the back just case clips and comes off fairly easy
Thank you. OH GOD thank you.
This isn’t true with this model. You have the Exnyos one. The Qualcomm one does not have a removable back..
JM M -
