Einleitung
Large amounts of adhesives are present on the backside of the screen. Exercise caution while working to avoid being cut by any broken glass in the screen.
Was du brauchst
Heat the iOpeners in a microwave for 1-2 minutes.
Place heated iOpeners on screen edges to heat the adhesive.
Separate the screen assembly from the back by wedging the picks between the two components.
Slide the picks along the edge and leave them holding the device open all around the edges.
Place suctioning device near the corner of the screen and gently lift up to create a gap between the front panel assembly and the back.
Insert the picks to hold the two components apart once a gap is created.
Once all edges have been disconnected, carefully lift the screen off by pulling one side up.
Using the tweezers, gently peel up on the silver tape covering the connector.
Use the plastic opening tool to get under the connector piece. This will allow you to remove the front panel assembly from the rest of the device.
Detach the connecter from the inside of the device.
Lift the screen to separate the front panel assembly from the rest of the device.
12 weitere Personen haben diese Anleitung absolviert.
3 Kommentare
Question. How is the new LCD re-attached? Do you reheat the old adhesive so that it sticks to the new LCD? Or do you need to apply new adhesive? Or is there a double-sided tape to re-attach the new LCD?
Hi,
my glass broke, not the LCD itself. Do you know how to separate LCD and glass, change the glass, and put it back again?
I have found a video on the internet but a laminating machine seems needed?? Any easier solution?
Thanks
I would like to know also
Chris -
