Einleitung
If your camera has been damaged or not working properly, use this guide to replace your front-facing camera.
Was du brauchst
Heat up an iOpener for 30 seconds and place on all four seams of the screen. A heat gun can be used as well.
The glue is now melted, so using the metal spudger shown, pry open all sides of the tablet.
When prying open near the home and touch screen buttons, use a suction cup.
Once lifted, flip the grey frame over.
This component connects to the sim card.
This is where the front-facing camera is located on the frame
Using the Blunt ESD Tweezer, disconnect the front-facing camera
Lift the camera
