Einleitung
If you need additional space to hold data like music, photos or games (among other things) you may need to insert an SD card into the device.
Was du brauchst
Using the tool supplied with the Galaxy Tab, insert the pointed end into the hole on the side of the device.
Apply pressure until the plastic SD card slot pops out.
Gently pull out the plastic insert completely.
Insert the Micro SD Card in the plastic insert, and replace it into the device.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
