Einleitung
The Samsung Galaxy Tab S3 motherboard replacement has multiple steps but once you have gone through the display and battery removal, the motherboard replacement is a straightforward process. Be warned that there are many connectors to undo. A malfunctioning can cause the device to not turn on, unusual visuals on the display, or if your device crashes regularly.
Was du brauchst
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
Place a suction cup near edge that you heated up with the iOpener.
Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
Use an opening tool to split apart the glass panel from the midframe.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
Pull off the glass panel using the suction cup.
Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
Use the black nylon spudger to lift the gray ZIF connector up and pull out the orange ribbon cable below the camera.
Remove the ribbon cable for the front facing camera after popping the red ZIF connector bar up with a spudger.
Disconnect the three press fit connectors in the top section of the midframe by prying upwards with the spudger.
Pull back the green tape on the upper section of the motherboard with your tweezers to reveal the ZIF connector below.
Push the red bar up from the ZIF connector with the spudger and pull the orange, touchpad ribbon cable out.
Use the spudger to disconnect five more press fit connectors on the left side of the motherboard by prying upwards.
Using your fingers, move all the cables aside and wiggle the motherboard free.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
