Einleitung
For the Samsung Galaxy TabPro S, model SM-W700NZKAXAR, it is important for the front-facing camera to be functional and not broken. The front-facing camera allows to take pictures with the front side of the tablet. Thus, the ability to capture real-time memories is lost without the front-facing camera.
Was du brauchst
Remove the back of the tablet by prying the plastic back using a flat tool.
When the tool has been inserted under the back, slide it all the way around the tablet to fully unclip it.
Use a Phillips #0 screwdriver to remove the screws that secure the motherboard.
Remove the metal plate once the screws are gone and the motherboard will be ready to be replaced.
Remove motherboard by prying it up with a flat plastic opening tool (not metal spudger).
Be sure that all components have been disconnected beforehand, especially the front-facing camera (located above the motherboard in the top center of the frame).
Once the camera has been disconnected from the motherboard, it can be removed using a pair of pliers.
