Zum Hauptinhalt wechseln
Samsung Galaxy Victory 4G Motherboard Replacement
Was du brauchst
  1. Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 Samsung Galaxy Victory 4G Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Place phone face down. Ensure the side with the display screen is not facing you.
    • Locate battery door and slide open.
    • Remove battery.
  2. Samsung Galaxy Victory 4G Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the 7 Phillips 3.93 mm labeled screws by using the Phillips #00 Precision Screwdriver.
  3. Samsung Galaxy Victory 4G Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use the plastic opening tool to pry open the back cover.
    • Insert the tool into the SD card slot and pry around the entire phone.
  4. Samsung Galaxy Victory 4G Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove one Phillips 3.93 mm screw from bottom center of the phone.
  5. Samsung Galaxy Victory 4G Motherboard Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Victory 4G Motherboard Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Victory 4G Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Carefully disconnect 3 ribbons at the shown location. To remove, place tool under the ribbon and pull slowly to avoid tearing.
  6. Samsung Galaxy Victory 4G Motherboard Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy Victory 4G Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
    • Place your tool under the labeled area and pull gently to detach the ribbon cable from the motherboard.
    • At this point the motherboard should be completely detached from the rest of the phone.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Zhao
251 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 15-3, Remmell Fall 2014 Mitglied von USF Tampa, Team 15-3, Remmell Fall 2014
USFT-REMMELL-F14S15G3
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 10
Insgesamt: 1,591
