Zum Hauptinhalt wechseln
Samsung Galaxy View Kickstand Replacement
Was du brauchst
  1. Samsung Galaxy View Kickstand Replacement, Kickstand: Schritt 1, Bild 1 von 1
    • Place the device on a hard flat surface with its screen facing downwards.
    • Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
  2. Samsung Galaxy View Kickstand Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy View Kickstand Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy View Kickstand Replacement: Schritt 2, Bild 3 von 3
    • Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
    • With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
    • Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
    • Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 4-5, Livingston Fall 2016 Mitglied von Cal Poly, Team 4-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G5
4 Mitglieder
12 Anleitungen geschrieben
15 Kommentare
Where do u buy a replacement kickstand
Bethann Stokes - Antwort
The only thing I could find was a broken one on eBay for parts ......
cindylou73 -
I have the same issue! kickstand broke in half (it fell and got broken) and cannot find replacement
Carlos Sierra -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 37
Insgesamt: 8,688
