Einleitung
Replacement of the motherboard requires the removal of the kickstand, battery, and speakers. The battery will be removed for user and device safety reasons.
Was du brauchst
Place the device on a hard flat surface with its screen facing downwards.
Rotate the the kickstand so that the handle grip hole is up in the air and not touching the back of the tablet.
Stick the pointy end of the spudger into the circular opening of the leftmost metallic latch.
With the spudger still inserted, pry the spudger to the right pushing the latch opening along with it.
Once the latch is moved to the right, pull up on the left side of the kickstand, releasing it from the back of the tablet.
Repeat the previous steps for the rightmost latch, and then lift the kickstand off the back of the tablet.
Check the device is completely turned off.
Slide open the SD compartment tab, and remove the SD card to ensure all data is saved.
Insert the plastic opening tool between the seam of the back panel and the front casing to create an initial opening.
Insert the metal spudger within the opening.
Move the metal spudger down the seam, prying the back panel open as you go.
Once a large enough opening is made, pry the entire back panel off with your hand.
Using the plastic opening tool, lift off the orange press-fit connector (marked with a white arrow-head) where it attaches to the motherboard.
Remove the 6 screws (4 mm in length) using the Phillips #0 screwdriver.
Remove the battery from the device.
Use the plastic opening tool to disconnect the white bundled cable connector that links the left speaker to the motherboard via a red wire.
Remove the left speaker by gripping it with your hand and lifting it off of the pegs.
Remove the right speaker by gripping it with your hand and pulling it straight up and off of the pegs.
Insert the plastic opening tool beneath the orange press-fit connector attached to the bottom left side of the motherboard and use a leverage motion to pry the connector from the board.
Repeat the above step for the other two orange press-fit connectors attached on the bottom left side of the motherboard.
Use the plastic opening tool to pry up on the blue antenna cable connector near the right edge of the motherboard.
Repeat the above for the black antenna cable connector positioned next to the blue wire.
Use a Phillips #00 screwdriver to remove the nine 3 mm screws around the motherboard.
16 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Hi… Where can I get a replacement motherboard for a Samsung galaxy view? I need one.
Hello I need the charger plugin and wire harness replacement parts. there tiny heres a screen shot of what is needed. If anyone knows where please posts info in reply thank you
[img]https://i.imgur.com/QMgrXkh.jpg[/img]
where can you find a replacement motherboard. seems like all you can you is buy a used one off ebay.
where can you buy a replacement motherboard. seems like only way is to buy a used unit off ebay.
