Einleitung
Use this guide to replace a cracked or broken screen on your Galaxy Watch.
Was du brauchst
Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
Use an opening tool to get between the back cover and the metal housing of the watch.
Carefully pry the plastic back cover open.
Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
Use a spudger to disconnect the display flex cable from the motherboard.
If necessary apply some tape over the display to avoid any injury from glass shards.
Use your finger or thumb to steadily push down on the display to loosen the adhesive.
Remove the display.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
