Zum Hauptinhalt wechseln
Samsung Galaxy Xcover GT-S5690 LCD Replacement
Was du brauchst
  1. Samsung Galaxy Xcover GT-S5690 LCD Replacement, LCD: Schritt 1, Bild 1 von 1
    • Here is the Samsung Galaxy Xcover, with the LCD broken, that will be replaced.
    Frag FixBot
    Kommentar hinzufügen
  2. Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 2, Bild 1 von 1
    • The first step, is remove the battery door. It comes with a security lock, that has to be on open position. Start opening from bottom, and releasing from the side edges.
    Frag FixBot
  3. Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 3, Bild 2 von 2
    • Remove with a flat screwdriver, the volume button and the power button
    • Now, with a Phillpis Screwdriver, remove all the screws from the backcover.
    Frag FixBot
  4. Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 4, Bild 1 von 2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 4, Bild 2 von 2
    • With a flat screwdriver or plastic opener, separate the front case from the rear case. It will be easy!
    Frag FixBot
  5. Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 5, Bild 1 von 3 Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 5, Bild 2 von 3 Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 5, Bild 3 von 3
    • Remove the screw on the lower zone of the main board. The screw is the same of the case, so dont worry if you mix them.
    • Now, with a pliers, unplug the camera and the front speaker. Now, we are going to lift the main board, but ...
    • be careful, below is the LCD flex cable!
    Frag FixBot
  6. Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 6, Bild 2 von 2
    • Remove the LCD flat cable, and then, remove the 2 screws on the sides of the front cover. They are the same as the others screws...
    • Now, you can take apart the chassis from the front cover, leaving only the display and the touch.
    Frag FixBot
  7. Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 7, Bild 1 von 2 Samsung Galaxy Xcover GT-S5690 LCD Replacement: Schritt 7, Bild 2 von 2
    • Lift up the black retainer, and take off the touch flex cable.
    • Be careful, the flex has double side tape below the IC.
    • Now, with a knife or cutter, lift carefully the LCD unit. Place the new LCD, and reassembly the phone.
    • In the near future, I´ll post how to replace the touch screen!
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Jaime
3.357 Reputation
4 Anleitungen geschrieben
1 Kommentar zur Anleitung
Good and clear. Pics are much better than movie, thank you very much!
pierrequivoyage - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 61
Insgesamt: 7,706
