Einleitung
This guide shall detail and illustrate how to replace the home button for a Samsung Galaxy Y in the situation of the home button not being responsive or broken.
Was du brauchst
Use the blue plastic opening tool to pry the back-panel off of the device.
Use the screwdriver with a Phillips #000 screwdriver head to remove the four 5mm screws located in the corner of the interior back panel.
Remove the SD card as well by sliding the card out of it's slot.
Use the metal pry tool to separate the interior back panel from the interior hardware and screen.
Disconnect the orange motherboard connection, then remove the interior hardware from the front screen display.
2 weitere Personen haben diese Anleitung absolviert.
